Samsung QLED, 49Q7F - Sky input appears as 'Sky Austria'
(Topic created on: 24-12-2017 11:35 AM)
roydonaldson
Hi there,
I have a Samsung QLED, 49Q7F and when I use the Smart Remote setup to setup my input as the Sky+HD input, it seems to work perfectly the first time I set this up. It creates a new input called 'Sky' and puts the correct Sky logo up to select. This is great ! and is exactly what I want.
However, if I turn the TV off and back on again, then it seems to have now renamed the input 'Sky Austria' ???
The only thing that is between the One Connect box and the Sky box is an ARC capable HDMI matrix from Fospower.
I don't understand why when it works perfectly, if I turn the TV off and back on again it renames it 'Sky Austria'.
My family really don't understands this ??
Thanks,
Roy.
0 REPLIES 0
