21-07-2021 11:58 AM
For some weeks there has been a voice in the background telling me what is happening Example "he is now walking over the grass" this is without subtitles on. I have tried everything even resetting TV.
Solved! Go to Solution.
21-07-2021 03:46 PM
21-07-2021 12:11 PM
Try
Step 1: Go to Settings from your TV’s home screen.
Step 2: Then, choose the General option.
Step 3: In the General option, select the Accessibility tab.
Step 4: Now, select the Audio Descriptions option.
Step 5: Just, turn off the toggle.
21-07-2021 02:53 PM
Thank you for your response but I have tried that and it is already turned off. I do have the a Virgin Tivo Box connected to the TV as well.
21-07-2021 03:46 PM
21-07-2021 09:53 PM
That worked thanks.
