13-01-2021 05:28 PM in
TVI've had my Q80T 49" now for a week. My issue is with the sound dropping out, it is literally happening on the hour, every hour. It only cuts out for 2-3 seconds, but is very annoying. For a £1000 television this shouldn't be happening. I have followed all the troubleshooting steps that others have recommended on this forum (changing HDMI ports, HDMI cables, sound test troubleshooting), but still seeing issues. This is happening while my Virgin Media 360 box is connected, also while using the Netflix App on the TV itself. Has anyone found a permanent fix for this? Very frustrating.
Solved! Go to Solution.
2 weeks ago in
TVAfter weeks of playing with various settings & testing them all out, I believe to have found the issue to actually be from my Virgin Media 360 set-top box, not the TV. After changing the sound setting from Dolby Audio. I had 3 options, Always convert, Follow content or disable. After disabling this setting, I've not seen an audio drop out in a few weeks now. So advice for people seeing this issue, check ALL your audio settings before blaming the TV.
15-01-2021 04:25 PM in
TV20-01-2021 01:38 AM in
TVJ'ai le même problème avec la xbox one X !
26-01-2021 03:12 PM in
TVPlease see my posts, and that of several others, on this very topic.
You won't be happy!
2 weeks ago in
