Samsung Q70B not detecting 5ghz wifi band
(Topic created on: 04-01-2024 06:20 AM)
Q70BOwner
I've recently bought the Q70B tv and when trying to connect to network it is not picking up WiFi 5ghz band. it only shows the 2,4 ghz band. The TV is located close to the router so it cannot be a range issue. 5 ghz works fine on my other devices.
1 REPLY 1
Gurky
Helping Hand
Hmm odd, try a whole reset of both Tv and router. If you turn on phone hotspot in 5gz does it pick that up?
