08-12-2020 07:33 AM - last edited 08-12-2020 10:33 AM ) in
TVDoes anyone know the cause of this on the bottom right of the screen? The TV was fine until a few days ago and this inexplicably happened. It's noticeable on lighter backgrounds, but not on black. The TV is only 2 years old!
08-12-2020 07:44 PM in
TVAren't there any mods on here?
08-12-2020 10:24 PM in
TVThank you for the reply .Yes I can get a picture okay.
10-12-2020 08:13 AM in
TVWell that was a waste of time
30-08-2021 04:20 PM in
TVI know it's over a year later, but in case anyone else is having similar trouble... This is an edge-lit TV, meaning there are LED strips that sit along the bottom, pointing straight up through the edge of the diffuser lens. This arrangement can cause excess heat to build up, blowing the LEDs and melting/cracking the diffuser. The bright spot in the picture looks like a diffuser crack.
I'm dealing with the same thing myself in a "broken" UM7100 model that I bought for next to nothing. After replacing the LEDs, I'm getting a similar bright spot (in the same place, actually), and discoloration all along the bottom from the literal brown spots where the diffuser is melted and burned. I've read that transparent aquarium glue inside the crack will help, but I haven't tried that yet.
27-11-2022 01:00 PM in
TVHey, did you try spinning the panel 180 degrees so the good edge is on the bottom? I have the same issue on my 43 and mine isn't cracked or burned too much but some surface melting. I'm waiting for my led strips, but heard you can turn in around and it works, but maybe not as bright?
