12-03-2017 01:52 PM in
TVJust received our new tv , unboxed , connected all cables to One Connect, then go into setup , updated firmware as it was out of date. All connected was a film vis the usb port TV after 2 hrs of watching tv , the tv suddenly goes blank , re-boots, then we get a picture come up saying “check one connect cable is connected to tv”, so I switch off, disconnect cable,re-connect same message again “check one connect cable is connected to tv”.
Is the tv or one connct faulty , I cant go into any menu at all only the picture of the connect box appears: help please kids are going bonkers around the house no TV EERRRR
14-03-2017 03:47 PM in
TVHey @adamb,
How's the TV at the moment?
If you haven't already, we'd advise speaking to our Support Team - they'll be able to diagnose the fault with you and arrange a repair if needed.
21-04-2017 02:37 AM in
TVwere you able to solve this problem with your tv? having the same exact issue on a brand new tv
