28-02-2017 03:39 PM
I purchased a
Samsung HG28ED690AB 28 HD Ready SMART Hospitality LED TV and fail to set it up without being on hospitality mode. I want to use this for normal use only. I also cannot manage to pick up my wifi on the TV to enable the smart TV to operate and download apps. Any suggestions.
Solved! Go to Solution.
04-11-2019 11:54 AM
Hi, i dont have network in that menu. Mine is 6 series 40.
03-01-2020 04:14 PM
How do I turn off hotel mode to activate my broadcast setup options such as auto tuning and channel list setting.
Does the hospitality mode has to be set to standalone or interactive?
Kindly help
28-02-2020 06:58 PM
I purchase my tv from a hotel closeout sale without a remote. And I need help to get it off hotel mode. Can you help me?
26-03-2020 05:09 AM
26-05-2020 04:06 PM
05-06-2020 10:11 AM
HI,
I also ave purchased a Hospitality TV (Model HG24EE690AB) and cannot get it to rest or bring up any menus using the "Mute-1-1-9-Enter" option.
When I do the above it will just key in the channel number (aloowing for 4 digits) and do nothing.
I have also tried all the other options posted to the web "Mute-1-8-2-Power", etc etc
Most of my menu options come up unavailable and I just want to be able to reset and start again.
My Smart Hub also only shows a browser App and nothing else (Download Apps not available).
Any ideas would be apprechiated!
18-06-2020 06:09 PM
I did the mute 119 enter thing but there isn't a network setting what do I do then
21-11-2020 01:16 AM
Hi, are you able to download apps on yung smart tv. I just bought mine and also having same issue.
23-09-2021 04:36 PM
Any luck?
26-02-2022 12:14 PM
I tried your solution and ended up like this, couldn't find a way to unlock the network settings, any ideas?
