28-02-2017 03:39 PM in
TVI purchased a
Samsung HG28ED690AB 28 HD Ready SMART Hospitality LED TV and fail to set it up without being on hospitality mode. I want to use this for normal use only. I also cannot manage to pick up my wifi on the TV to enable the smart TV to operate and download apps. Any suggestions.
Solved! Go to Solution.
09-03-2017 11:16 AM in
TVHi @AlbertoP,
Can you try this:
Select the Network Type you wish to use and proceed with the setup.
02-03-2017 11:54 AM in
TVHi @PB1963,
Did you select 'Standalone setup' when setting up the TV initially? Is the TV not finding any networks, or is it failing to connect? Can you setup a mobile hotspot for testing purposes and let us know if this allows a connection?
04-03-2017 07:57 PM in
TVHi,
I also have this problem. I bought this TV two days ago, I set up the "Standalone setup" at the beginning. I have full access to the menu and tools options. However, if I go to Menu -> Network, the options "Network Status" and "Network Settings" are not available. When trying to enter any of them I receive the message "This function isn't available".
I have tried to set up a Wifi hotspot, and it does work, as I can see the network on my laptop. However, because I haven't been able to setup a wifi connection on the TV, the hotspot wouldn't work.
I guess I just need to know why I cannot access the "Network Settings" option.
Thanks in advance for your help.
TVHi @AlbertoP,
Can you try this:
04-09-2017 01:25 AM in
TVI am having similar trouble with the model TV, final suffix is XXU (if it helps).
I have no apps other than a web browser and cannot access some menu items as described by others, such as network settings. Since the browser functions, I guess the netwrok must be active.
I tried the tip you gave previously:
This does not open the Hotel Options Menu as stated. In fact, the TV switches on (I see the Samsung Logo) as soon as I press "9". Pressing "Enter" does nothing and I always get the "Home" screen with a large blank box (no antenna is connected), an "Information" button at its top right, and some function boxes down the right side, including Source and Menu.
This is incredibly irritating. I have been trawling the internet for hours, trying different suggestions from countless people and getting nowhere. I just want a TV with smart tv functions, particularly online apps, not just a browser.
23-03-2019 02:17 AM in
TVDo what he said. Mute, 1, 1, 9, Enter.
Not only the menu pops up.
Top left of the screen go down to TV Reset.
This is going to ***** off the maintenance guy.
But, I am the maintenance guy.
Start the TV up do it for Digital TV.
You'll have your apps. But I'm gonna have too set your TV up again!
26-05-2019 12:56 PM in
TVHi just purchased the tv mentioned above got the tv on but can't download any apps like it hub etc and Netflix. Any suggestions. We had to reset the tv as it was in hospitality mode obv a return but still no apps any help appreciated. Step by step guide to get the apps as a lady and no clue
28-05-2019 09:52 PM in
TV03-07-2019 12:50 AM in
TVWhat if I don't have original remote
03-07-2019 02:44 AM in
TVThey're easy to find.
This one's in the UK...
https://www.ebay.co.uk/itm/383020319444
