03-03-2021 09:48 PM
Solved! Go to Solution.
05-03-2021 09:16 AM
I used the webchat and tried the reset solution which worked! Turns out the moving of the one connect box was irrelevant. Just hold the power button for 20 seconds and it should fix.
04-03-2021 12:09 PM
I have the same issue and I've not touched or moved anything. It was ok yesterday but not today.
Please help!
05-03-2021 09:16 AM
