S95b tv. HDR
(Topic created on: 26-02-2023 11:39 AM)
Adam67
Does HDR somehow set up in this tv. Is there any hidden settings. If so, how to get there.
8 REPLIES 8
Ginga_p
Troubleshooter
Have you tried going to settings and connections (i think) look for external device manager then signal plus and turn the hdmi you want hdr on
G G
Adam67
Did that as well
Adam67
But what if the signal comes from an application such as netflix. I can not find any settings for HDR all settings are to SD
JAMES4578
Samsung Members Star ★★
@Adam67  The native applications(i.e the Tv apps)  automatically display HDR when appropriate content is selected.  Input Signal plus  (UHD colour in some  older models) only applies to HDMI connections.    you have the option of adjusting the Gamma setting (basically highlights and shadows)  and difference between ST 2084 and HLG explained here for those interested  https://www.murideo.com/news/what-you-need-to-know-about-uhdtv
 Experimenting with different picture Modes can make a difference, Film Maker Mode for this Tv may be best for HDR.   A bit about the TV settings in this article https://www.rtings.com/tv/reviews/samsung/s95b-oled
Adam67
Thank you
Ginga_p
Troubleshooter
Do you have a fast Internet.
G G
Adam67
Yes I do
Leerolph
Pioneer
Do you have the top tier Netflix plan?
only the top tier allows you to play in 4k HDR
