Routing Q6 sound to Lenovo laptop via Bluetooth
(Topic created on: 27/10/19 17:52)
MartynA2905
New Member
TV
Hello,
I’m trying to set up a bluetooth link between my Q6 (2018) Oled TV and my Lenovo laptop so that I can listen to the TV’s sound without disturbing others in the room.
I have paired the two, and am trying to get my laptop to appear in the list under Settings -> Sound -> Sound Output - Speaker List but it seems that I must do a bluetooth connect from the laptop to get it to appear there. But the problem is that as soon as I click ‘Connect’ on the paired connection in my Win10 system-tray bluetooth menu, the TV immediately goes into Ambient mode and will not exit from it unless I disconnect the bluetooth connection. In Ambient, it only seems to want to play music from my laptop, which is of course the opposite of what I am trying to do.
Am I missing a step or going about this the wrong way?
1 REPLY 1
SaudA
TV
Hi @MartynA2905
Do you still need help with this? I recommend getting in touch with our Audio Visual Specialists, as they will need to take you through some advanced steps. They can be contacted on 0333 000 0333.
