Go to solution Solved
Removing Region Selection Samsung Smart TV
(Topic created on: 28-08-2018 10:42 AM)
LMH
Every time I turn on my TV, 'region selection' pops up. I already completed it during set up, but it persists on each start up of the TV, which is very annoying. Does anyone know how to stop this? Thank you
LMH
Hello Everyone,
Since posting the query, I have been playing around with the TV. I did something and think the Region Selection is now gone. The morning after the change, frustratingly, it still appeared. However, I have not seen it since, which was 5 days ago. Please try this, and let me know if it works for you. FYI, I have a 7 Series.
1. Settings
2. Broadcasting
3. Auto Tuning Settings
4. Standby Auto Tuning - turn this OFF
My TV had been set to Auto Tune 2 hours after turning TV off. My theory is that the fresh tuning is the reason the TV kept asking for Region Selection to be made.
Please do post what results you get from these changes.
Thanks
57 REPLIES 57
AM73
I am also experiencing the same issue - Samsung 8 series 65
Ben_
Also experiencing the same issue on Samsung 7 Series
ChapelJeff
So am I (Series 7).  Would also like to disable the timed switchoff.
LMH
Hello Everyone,
1. Settings
2. Broadcasting
Thanks
LMH
Hello ChapelJeff
Are you trying to disable the 'Sleep' and/or the 'Off' Timers?
If so, try as below.
1. Settings
2. General
3. System Manager
4. Time
5. Sleep Timer or Off Timer - Turn OFF
Hope it works for you
AM73
Cheers. Will post back in a few days if it works.
ChapelJeff
Thanks for that - it appears to be working.
AM73
That seems to have done the trick.
I havent had the region selection pop up since I changed the auto tune settings.
Cheers
AM73
double post...
