Remote control volume button controlling Receiver option?
(Topic created on: 04-12-2018 01:26 AM)
oliverkl23
When I try and control the TV volume from the Samsung remote it is prompting wwith “Receiver. (HDMI)” rather than Volume. I’ve power cycled the tv and have removed the batteries from the remote and put them back in and the issue continues. I do have an HDMI ARC sound bar connected and that works from the remote control for it.
2 REPLIES 2
CarlH
Maestro
Hi @oliverkl23. Can you tell me the full model number, located on the back of the TV?
Members_T1vd5MG
I had a similar kind of an issue where Samsung remote stopped working as designed. It was not allowing to increase or decrease the volume but was showing a box saying, Optional. I understood, its a small setting which we needed to change and it started working again. I went to setting, set the sound mode to standard and it worked again.
