Remote control issues on Samsung
(Topic created on: 10-10-2022 10:49 AM)
Judis
Hi on my remote if I try using the channel up or down buttons it takes me straight to Samsung TV plus? Is this a setting issue? Also channel list only shows Samsung TV plus channels? Please can some one help thank you
1 REPLY 1
Jake01
If you press the Channel List button on the remote, you should see a check box in the top corner. Make sure All Channels is checked, not Samsung TV Plus.
