12-12-2016 02:08 PM in
TVHow to toggle between previous viewed channel and next channel? The back button on remote doesn't seem to work. This basic feature works on dumb TVs but not on Samsung Smart Tvs
Solved! Go to Solution.
13-12-2016 01:45 PM in
TVYour TV is not a UK model, in this case you can use channel UP and DOWN or Pre-CH button to return to the previous channel but the TV is unable to use the RETURN button to do this.
We hope this clarifies everything. :smileyhappy:
12-12-2016 04:50 PM in
TVHi oto!
Is this for a UE55J5672SUXXH? And can you send us a pic of the button on the remote you're referring to?
12-12-2016 08:20 PM - last edited 13-12-2016 05:19 PM ) in
TVI mean "↺RETURN" button. On other TVs it allows to jump back to previous channel so while watching one channel and there are commercials I can quickly jump back to other channel.
06-10-2020 02:01 AM in
TVI hear you. In a future TV software upgrade they could default the icon selection highlight to the second position when the channel history icon menu is displayed at the bottom of the screen. This would make "return to the previous channel" a 2 click function. As an alternative solution they could simply allow customers to use the "↺" return arrow on the left side of the one remote when it is not required to return to a previous page or menu. A Cable or over the air channel should be in use if using this option.
