Go to solution Solved
Registering Smart Tv
(Topic created on: 07-07-2017 09:03 PM)
Sam1999
I've been trying to activate/ redgister the warrenty on my Tv I bought, however after spending hours searching the entire website I can't find anything about registering my device. In the 'accessories' pack that came with the Tv it gave a web address to follow to register, www.samsung.com/uk/register , but no matter what I try the website will not come up.l
ChrisM
SuperStar
Hi @Sam1999.
Not to worry! Your TV's warranty automatically kicks into play as soon as you've bought the TV. You can, however, register it by logging into your Samsung account here.
5 REPLIES 5
ChrisM
SuperStar
Hi @Sam1999.
Superglo69
Only if the product is actually listed    as it registers automatically on certain models of TV's I have just checked as soon as you activate the tv it is installed on the Tv settings
Superglo69
At the moment I can not register either and the call centre is a no go and so is the chat not much help I just tried and he hung up
Superglo69
fe10
I have spent half an hour trying to register my TV total night mare trying to scroll through all the models you can just eneter you model. Waste of time
