18-04-2021 01:35 PM
Hi!
Just received a new Samsung Q95T 65 inch TV, and I need some guiding on calibration/settings. Do you have any recommendations or links to good and easy guides to get me going?
As far as I know the only thing I should turn off is something called motion smoothness - I am not entirely sure what it is, other than that it might create som blurry pictures. The TV is mostly going to be used for streaming different TV series (mostly Netflix) and some ordinary linear TV watching.
Would also like to know if it's possible to know what quality is streaming on the TV? I have upgraded to Netflix premium, allowing 4k streaming - but the TV is in a bad spot for the wifi, so I am a bit unsure if I am getting value for the money or if the TV is still only streaming in regular HD.
18-04-2021 03:34 PM
18-04-2021 03:36 PM - last edited 18-04-2021 04:51 PM
Thanks, I'll check it out.
Do you know if it is possible to check the resolution of what is streaming to the TV? Is there some kind of info you can check on the samsung TV?
EDIT: I can adjust blur reduction, judder reduction, turn on/off LED clear motion, and noise reduction. How should I adjust them?
default (if set to auto):
Blur reduction: 10
Judder reduction: 8
Led clear motion: OFF
Noise reduction: Auto
18-04-2021 09:21 PM
19-04-2021 07:41 AM
Thanks for the tip. It looks like the eco mode is already turned off since I have intelligent mode activated.
19-04-2021 07:57 AM
19-04-2021 07:59 AM
19-04-2021 05:40 PM
Thanks, it doesn't show on the Q95T to me at least, unless there's a way to show it that I don't know 😕
13-09-2021 01:53 PM
18-09-2021 03:42 PM
Still not found the optimal settings tbh, and still wondering if I should have Auto Motion Pluss turned off completely or set to auto. There are some pros and cons. But in general, for watching TV series and movies (on Netflix for instance), would it be best to have it turned on or off?
