28-12-2021 12:34 PM
Hey,
When I had the Q90R, the One Connect cable was thinner and you could bend it a little bit.
Also , where the cable was attached to the tv, it had a little screw that secured the cable, so that you couldn't drag it on it.
With the QN95A, it seems like Samsung has been in a hurry, not using a screw anymore to secure the bigger connector to the tv. Instead you get a kind of little flimsy plastic thing, that should hold the cable in place. To start out with, I don't like it 🙂
I've attached my tv on the stand, and the cable just kind of hangs in the tv connector locking mechanism. The little plastic thing doesn't do much on the cable.
Guys, how did you secure the thicker cable properly, without damaging the cable by bending it too much? It's really hard / impossible to make it fit nicely down in the stand, as its not really bendable.
