09-09-2021 02:04 PM in
TVSince the update last week I have just noticed that picture clarity settings is disabled for all picture modes for BBC iPlayer. No motion smoothing available at all.
Other built in apps Amazon, Netflix and Disney are fine fortunately but why has it changed for iPlayer?
Needs to be re-enabled
14-02-2022 01:13 PM in
TVHi Mark, this isn't helpful at all for you, but I have exactly the same issue which persists into software version 1904. Technical support seem oblivious to it when I have chatted with them on a couple of occasions. Have you had any luck resolving this? Also, hopefully this bumps the query up the list a bit so someone can get to work on it!
