QN700B Remote
(Topic created on: 06-10-2022 01:15 PM)
Ricko_mcv
Please could someone help me out, I need a new remote. Does anyone have a link for the specific remote for this model? Thank you.
4 REPLIES 4
A-FAST-ASSISTsimple
Pathfinder
What is the model I'll search it for you
JAMES4578
Samsung Members Star ★★
Hi @Ricko_mcv  I do not see a direct replacement on Samsung Spare Parts , can check here and may be a compatible one https://www.samsungspares.co.uk/?&gclid=EAIaIQobChMIp4f_9v_L-gIViLrtCh10CQHgEAAYASAAEgIdJPD_BwE
The applicable Universal Remote should work , https://techpenny.com/samsung-remotes-universal/    Can also check on Amazon https://www.amazon.co.uk/s?k=samsung+universal+remote
kamil40013
Samsung Members Star ★★★
@Ricko_mcv, Search for an TM2280E. This is exact model that you need. Older models will probably work too, but I advice you to buy model that came with the TV.
You should be able to buy one at Samsung Authorised Service Centre.
Ricko_mcv
Thanks for your help, appreciate it.
