20-12-2019 08:24 AM - last edited 20-12-2019 08:28 AM
So far Samsung havent answered my enqiries so wonder if the community can help.
I have a new QLED 70 TV which does not recognise my set top box.I have tried switching cables and input ports.If I turn on Input signal plus then I can get a picture but no sound .I then have to turn iInput signal plus off again in order to get sound.If I dont do this I get a pale purple screen. The set top box works fine on my other TV and the Qled recognises other devices.
20-12-2019 06:33 PM
22-12-2019 05:47 AM - last edited 23-12-2019 09:49 AM
Thanks.for your reply.I can not see the option to change screen resolution through that process.
I can change screen resolution using the set top box menu with no difference.
The television will display a full picture with sound if I only follow rhe above steps.
If I reactivate Input signal plus I can get a picture only on boot up with no sound.To get picture and sound and have to activate and then deactivate input signal plus each time the set top box is turned on.Does you have any thoughts on what role Input signal plus has in this
