QLED 2018 with Alexa
(Topic created on: 03-06-2019 11:53 AM)
Adrian-J
Hi
i have a Q9 QLED tv 2018 model
alexa can turn it off but rest of time whilst it appears as “disconnected” in the smart things app Alexa can not turn it on/off
i do not have a separate smart things hub
-will this help ?
any help appreciated
ps I think the 2019 model has added Alexa support I wander if the 2018’s will get an update ?
4 REPLIES 4
CarlH
Hi @Adrian-J. Is your TV currently connected using an ethernet cable? If so, this could be the issue as it needs to be connected using Wi-Fi.
Adrian-J
  • Hiya Carl
thanks for reply
yes tv by cable -WiFi wasn’t good for the 4K content so I need to keep it connected by cable
you connect tv via WiFi & get Alexa functionality  2018 model ?
CarlH
That's right, the on/off feature should work using Wi-Fi with your model, @Adrian-J
Adrian-J
Thanks again Carl
Shame as I must keep it hard wired
I might try one of those harmony signal senders for complete control
Big thanks
