QF9 AirPlay settings problem
(Topic created on: 20-06-2019 10:25 PM)
dsp92
TV
Hello
Apple AirPlay settings under General settings function does not work, nothing appear when I click on them (it’s  like a freeze on the settings options, I have to force quit by long press back button to return to home screen).
i cannot setup the AirPlay code and use The feature even if it’s seems working because I see the tv on airplay display but can’t cast without the code entered into settings.
thanks for your help.
2 REPLIES 2
vince034
Navigator
TV
Did you try to unplug your tv and plug it again?
dsp92
TV
I already tried reset the tv, change language, disconnect power, disconnect network. Nothings works.
apple tv application works perfectly.
