QE65Q85TATXXU sound
(Topic created on: 24-09-2020 04:08 PM)
GaryO
On the sound menu I only have Standard and Amplified there is no Optimised option as the manual states, is this correct?
2 REPLIES 2
AndrewL
@GaryO: With the Sound Output set to TV Speaker, you can set the Sound Output to 'Standard' or 'Amplified' only. I was unable to find a reference to the Optimised sound option, although this may become available if you have the sound set to output via an external speaker.
leonbakhan
Yes it is so.
The other variable or functions are available only when an external sound system is connected.
