08-06-2020 10:02 PM
After around 2hrs of television being on there is some flickering lines appears on the screen. If I unplug the invisible cable from behind the one connect box and reinstall the flickering disappears.
any suggestions?
chris
09-06-2020 10:08 AM
Hi @Pitt1 ,
do you still have this issue? If so, can you check if the invisible cable is connected correctly at the back and if this is presenting any kind of damage?
09-06-2020 07:38 PM
Hi. The connection is good at the television and box. The invisible cable does not move nor is it disconnected. I unplug the invisible cable from the box end, plug it back in and the interference type lines disappear. It's a 2 year old television this coming September.
chris
11-06-2020 09:55 PM
Hi is there any suggestions on this. I unplug the invisible cable and plug it back in again and lines disappear. Is this an indicator of the box being faulty or the cable?
chris
16-06-2020 09:45 PM
17-06-2020 05:36 PM
The cable is my best bet especially if you have caught it with something. It could be something small like somthng sitting on it.
