04-06-2022 11:08 AM in
TVHi.
Was told by Samsung support that the 2021 Slim Fit Wall Mount would be compatible with my new 55QN95B. After buying the 2021 Wall Mount I noticed the installation manuals inside don't include measurements for the new 2022 TVs. Now I'm having a hard time with Samsung support in order to get these updated measurements (ABCD measurements in the Slim Fit Wall Mount guide for my specific model). The 2021 Slim Fit Wall Mount (#https://www.samsung.com/uk/tv-accessories/slim-fit-wall-mount-wmn-a50eb-xc/) and the 2022 Slim Fit Wall Mount (WMN-B50EB) are equal right (with upgraded instructions)? They sure seem to. Any way of getting the updated manuals that come with the 2022 Slim Fit Wall Mount? It's a simple measurement table! Also, what's the justification for both manuals not being accessible online???
Thanks!
