27-05-2023 07:02 PM
Is it possible to enable HBBTV on the QE55Q83BATXXC TV,
and
is it possible to configure simultaneous sound reception on TV speakers and Bluetooth headphones?
Solved! Go to Solution.
27-05-2023 09:55 PM
27-05-2023 09:55 PM
28-05-2023 03:00 PM
Yes it works (sound dual audio).
Thanks very much.
But I still need a solution regarding HbbTV.
There should be an app in the Samsung Store but I don't see it. Maybe it exists (apps) outside the Samsung Store and can be downloaded and installed from a USB?
