11-10-2019 06:47 PM in
TVHave signal issues from all external device connected from a HDMI.
The TV will recognise the device, Youview/Nintendo Switch/Xbox and will show their logo on the TV menu and under source, however I have no signal. The TV also recognises when the device is either on or off (as the standby symbol disappears when the power is on) and when I turn the power on the the TV will switch to the correct HDMI, however still No Signal.
I first thought it was a faulty One Connect box (model soc1001n) so I tried another One Connect box and still No Signal.
The TV has the latest firmware 1270.6
I've tried,
1. Powering the TV off by holding the remote power button, the TV resets and Samsung QLED TV logo appears
2. Removing all cables and power from the one connect box and left it for 30min to cool. I then reconnected everything and it still doesn't work.
3. As above and holding the power button down for 30 secs and then reconnect everything
4. I've reset the TV back to factory settings
All with no joy. (All my cables and external device work fine)
Any ideas to fix this issue? I feel at my wit's end.
Many Thanks
11-10-2019 06:49 PM in
TV
@Danffk wrote:Have signal issues from all external device connected from a HDMI.
I've tried,
Many Thanks
Sounds like it is faulty. Report it to your retailer, as they are responsible.
25-10-2019 10:43 PM in
TVI have exactly same problem... any hints please?
26-10-2019 06:48 AM in
TV
