QE55Q7FAMT TV
(Topic created on: 10-04-2020 11:59 PM)
Tee2
I am having problem with tv when watching it keeps turning off then on again only after the first hour
13 REPLIES 13
AsadM
Hi @Tee2. Hope you're doing well. Can you please give more information on what you're experiencing with the TV? Does this happen on any particular sources, apps, or channels?
Do you have anything connected to the TV?
Also, can you please confirm the software version on your TV? You can check this in Support > Software Update.
Tee2
Hi Asadm,
yes it normally starts after about 1 hour of watching tv or any other source I have a one connect box software is 1280
AsadM
Thanks for confirming, @Tee2. Let's try disconnecting everything from the TV and One Connect Box, and unplug it from the socket for 30 seconds. When you set up the TV again, please monitor this.
Tee2
I have tried to that but still same problem
AsadM
What other steps have you tried?
Tee2
I have tried new batteries in remote also disconnecting everything and stating again update on software
AsadM
Thanks for confirming. Let's try a soft reset on the TV. You can do this by going into Support > Self Diagnosis > Reset.
Tee2
Is it the reset smart hub or just reset there is two options
AsadM
This is just 'Reset'. Do let us know how you get on.
