qa43ls03bawxxy One connect Cable
(Topic created on: 14-11-2022 10:09 PM)
BenJ777
Hello,
Purchased the following TV and had an electrician install and ran cable through walls only to find out the 15m cable which i purchased isn't compatible -
43" The Frame QLED 4K Smart TV (2022)
QA43LS03BAWXXY
Does anybody know of either a genuine or 3rd party 15m cable which is compatible with this model?
2 REPLIES 2
DaniDayDream
Hi there. May I ask what the cable is for? If its Internet, can it not work via WiFi? I also have a Samsung TV and was tempted to drill through walls before trying it out and it works perfectly with streaming providing you have good Internet package. I hope this helps.
obitv
Pathfinder
@BenJ777 try this part no VG-SOCR15/XC
