Q95t - One Connect Invisible Cable - 15m Cable
(Topic created on: 30-06-2020 02:35 PM)
caramba80
TV
Hello all,
Sorry if this has been answered. I have searched and searched, but cannot work out how to buy a 15m invisible connection for the Q95t 4k QLED (2020) one connect box.
Please could you help with a model number and/or a link to one which works with the 2020 Q95t 4k?
Thank you.
Best regards,
Caramba80
13 REPLIES 13
TessM
TV
Aftenoon @caramba80 ,
our Online Shop is not currently selling this one (VG-SOCN15/XC), however, I can happily recommend the following three retailers to get one of these cables:
http://www.4ourhouse.co.uk/
http://www.espares.co.uk/browse/ma596/samsung
http://www.partmaster.co.uk/samsung-parts/shop.pl
caramba80
TV
Thank you.
There seems to be a difference between OCR15 and OCN15 - please before I order this, could I confirm that the model you describe below will work with the 2020 4K Q95T? I just wanted to double check.
Beat regards,
Mukund
TessM
TV
Sure! Can you confirm the full model code of the TV so we can ensure that this is compatible? This can be found at the back on a white sticker.
caramba80
TV
Hello
Sorry for taking ages to get back to you.
The full model code is
QE65Q95TATXXU
Version No.
01/QTQ95T/QTQ95T-Q65TP2
I hope that helps. If you can confirm that the suggested model of the 15m one connect cable is right, I will go ahead and buy it.
Thank you @TessM
AndrewL
TV
@caramba80: Please be aware that you will require the VG-SOCR15/XC cable, which is compatible with 2019 and 2020 Q range models.
Manny22
TV
Hi I purchased a 15m one connect cable in march my builder installed it so it now hidden in the dry wall. I purchased the tv last week and tried to install today only to find there is a new one connect cable and box and my cable purchased only a few months ago is no longer current. Are there any adapters? Or do i now have to purchase a new cable if so its going to be a nightmare to re install and both my builder and decorator just finished.
Marco319
TV
Hi, did it work with the Q95T and the VG-SOCR15/XC ?
caramba80
TV
https://www.amazon.co.uk/gp/product/B07SNFDP44/
This worked for me. Good luck.
Martin_1977
TV
Hello
Would like to know if the VG-SOCR15/XC is compatible with the FRAME 2020,  QE55LS03TAUXXC.-
Some samsung technical help desk says its not compatible(they still no produce a 2020 model) and others yes.- apreciate answer before i buy to be 100% sure
thanks
