Q950TS bezel gap
(Topic created on: 10-09-2020 08:06 AM)
Marcusdr
Pioneer
Hi.
Has anyone had any issues with there being a gap between the edge of the screen and the metal edge? Had two Q905TS with the exact same issue now on the lower left side. Terrible quality control by Samsung. The gap is so bad that light escapes through it so looks ridiculous when trying to watch TV. When you pay for a premium product you don't expect this.
Thanks
2 REPLIES 2
TD94
yes mine is the same. arrived this week. what did you do to get this resolved?20201101_224111_508.jpg
Marcusdr
Pioneer
Had 5 of them all with the same issue. Had them from different stock batches as well. Got sick of swapping them so went with a Q95T instead because I wanted a one connect box. Samsung have no quality control or the design of the Q950TS is just to ambitious.
