Q90T vertical banding
(Topic created on: 13-11-2020 08:19 PM)
RAK1
IMG_0838.jpegI purchased a Q90T 65” LCD directly from Amazon in May 2020. Six months later it developed “vertical banding” – see attached figures. Samsung sent out a technician who looked at the display and said that I must have damaged the screen “somehow.” That was ridiculous as we have not moved this TV since it was unboxed and installed – it weighs 85 pounds. Any thoughts?
8 REPLIES 8
DUMITRU79
Troubleshooter
Have you tried a factory reset ?
On your "not so smart " remote press Info + Settings + Mute + Power which will get you into "service menu " . You select "options " and then "factory reset "
RAK1
Good idea and yes, I tried this to no avail.
Thanks
DUMITRU79
Troubleshooter
Well then, if you still have warranty left , just send it back 🙂
Gumpy321
That TV is clearly smashed. You won't get anywhere with returning it. I hope you have home contents insurance!
RAK1
This TV weighs 85 lb and sits in an alcove in our living room - it has not been moved or damaged. Samsung is known to have LCD TV problems: https://www.consumeraffairs.com/home_electronics/samsung_tv.html
My next TV will be an LG or SONY.
RAK1
Amazon refused to take it back. They said to contact Samsung.
Gumpy321
Well they would, as its damaged. Samsung will refuse as well.
RAK1
After ~ 6 weeks SAMSUNG agreed to replace the LED panel under warranty and I now have a basically new TV.  Thanks to Van in SAMSUNG customer care.
