Q90R TV, not streaming until hard reset
(Topic created on: 05-04-2020 11:58 AM)
Fendo
Hi,
A couple of months I purhased a Q90R TV and it's great untill we bumped into this problem:
When someone already viewed a streaming video (via netflix or other streaming app) the TV will load all content (preview images) but won't load a streaming video. When I hard reset the TV (press and hold the power button on the remote for 8 seconds and QLED symbol is displayed) it can stream video's again.
I already reserved a IP address on our WIFI router for the TV as it disconnected a lot.
Anyone know how to solve this? Also, how can I setup a fixed IP for the TV?
1 REPLY 1
BigRedSun
Hi, Sorry I can’t help with the main question, but I can point you towards an answer for the fixed IP one.
When I have needed to lock a device to a specific IP, it’s been possible from the router interface.
Hopefully, once you get to the gateway of your router and look at the connected devices, you can find a way to switch each device from dynamic port allocation to fixed. Try looking for dhcp settings.
Hope that helps a little.
