01-10-2022 09:39 PM in
Hi,
Just upgraded to a Q90B from a Q91A so gone from Tizen 6 to 6.5.
Can you get to the Sky menu using the solar remote?
On my old tv you could scroll across to Sky, scroll up and press Home to take me to the menu. I have attached a picture showing this for reference.
I can't find these options on the Q90B so I have to use the Sky remote in addition.
02-10-2022 01:25 AM - last edited 02-10-2022 01:26 AM
Hi @joekbm I am aware there seems to be an issue on the newer Models. One Member found only workaround was go to Settings/123/RGB button, then navigating up/down to the 'control' section (below the numbers section), then navigating left/right to find the right button.
see this thread here https://eu.community.samsung.com/t5/tv/qn900b-remote-vs-sky-q/td-p/5824294
One Ui 5.1,Android 13 .
