Q900R Connect Box 2.1 upgrade how?
(Topic created on: 17/08/20 11:50)
Sxapap
TV
Hello. Has anyone found a solution to how they could upgrade their connect box? From SOC1005R model to i i think it was SOC300R?
3 REPLIES 3
PeerNorway
Voyager
TV
I am not so sure I understand your question correctly, but what you do is contact Samsung, and they will offer to send you a brand new One Connect Box (OCB) replacement, and you have to return the old one that came with your TV. This new OCB should fix the "HDMI 2.1 issue" or at least fix HDMI port 4 so it will be able to "accept 8K 60p", though there are some unclear reports what exactly this new HDMI port really is…
Danielecalabrese75
TV
Will this apply to samsung in thailand?
PeerNorway
Voyager
TV
It depends on what TV model you have, but if you have the Q900R it says on the product page that Samsung will give you an upgrade to HDMI 2.1.
