Q70 49" TV fault - crashes switches back on crahaes again
(Topic created on: 09-04-2020 07:35 PM)
James2687
my 2 month old Samsung Q70 has developed a fault where it switches itself off and the turns itself back on displaying a Samsung QLED TV logo. No image comes back on from the TV it then switches itself back off and starts the whole thing again.
Yes, I have unplugged for at least 30 seconds and plug it back in, it continues the loop.
1 REPLY 1
AndrewL
@James2687: Based on what you have described, I recommend reaching out to a Samsung Support Centre to arrange for an engineer to inspect your TV. To find your nearest one, please check the following link, select 'TV & AV > Television, and enter your post code.
https://www.samsung.com/uk/support/service-centre/
