Q60T PC to TV Mirroring / Casting over wifi
(Topic created on: 10-07-2021 04:03 PM)
K3n0b1
Navigator
So this TV doesn't let you mirror directly from PC to TV over wifi, which is annoying. It only lets you do it over HDMI.
Instead, I want to find a device to plug into the TV so I can cast my Windows10 PC screen, and mirror that way.
Looking for something fast with the least amount of lag as I will be doing some gaming.
Any suggestions? 🤔
2 REPLIES 2
Pugs1957
Samsung Members Star ★
K3n0b1
Navigator
No. The Q60T doesn't let you mirror directly from PC to TV over wifi.
Higher spec models do using the multi view function, but the Q60T only lets mobiles use multi view, not PC.
