Q-Symphony option not appearing
(Topic created on: 25-12-2020 06:50 PM)
Carll
Hi
I have seen various posts from others who had problems with the Q-Symphony option not appearing.
I have just purchased the Q80T TV and S60 sound bar both of which are compatible with Q-Symphony yet there is no option to select TV plus sound bar within the TV sound menu.
I have a brand new 2.1 HDMI cable so this should not be the problem and it is plugged into the E-ARC port.
The TV does recognise the sound bar, it just will not go into Q-Symphony mode.
Did anyone who had this problem solve it?
1 REPLY 1
cmhorn
I have the Q80T and the HW Q900T and it isn't there. I am guessing they pulled the option out.
