Go to solution Solved
Product review
(Topic created on: 11-05-2021 04:16 PM)
Yu-Ho
What is the difference between the T5300 Full HD HDR Smart TV with Tizen OS and the UE32T5300? The latter is sold at a cheaper price but I cannot spot any difference. Can anyone explain?
antikythera
Black Belt
It's the same TV, the latter is the long model number for it
2 REPLIES 2
antikythera
Black Belt
DannyT
You may be looking at a larger and smaller screen size.
Welcome to the Community!
