Go to solution Solved
Problem with Q70b
(Topic created on: 13-06-2023 04:14 PM)
Theo1896
Hello everyone.I have a problem with my new 3 month tv q70b.
The brightness is down to 90% from usual,I have tried everything myself, I have spoken with Support,we have seen everything ,we made a factory reset and they have told me that this problem is caused from an update.
Is it possible ?
They told me to wait 1 day.
What is your opinion?
Thank you
Neo001
Legend
It seems that a new software update will be released that is expected to fix this issue.
More details here (in Dutch).
https://eu.community.samsung.com/t5/televisie/beeldscherm-donker/td-p/7633057
8 REPLIES 8
AndrewL
@Theo1896: Please can you try resetting your picture, and checking the following options.
1. Home > Menu > Settings > All Settings > Picture > Expert Settings > Reset Picture
2. Home > Menu > Settings > All Settings > General & Privacy > Power and Energy Saving > Brightness Optimisation > Off
3. Home > Menu > Settings > All Settings > General & Privacy > Power and Energy Saving > Brightness reduction > Off
4. Home > Menu > Settings > All Settings > Picture > Expert Settings > Brightness, Contrast and Peak Brightness (adjust accordingly).
5. Menu > Settings > All Settings > General & Privacy > Intelligent Mode Settings > Intelligent Mode > Adaptive Picture > Off.
Let me know how you get on.
Theo1896
First of all thank you Andrew for your immediate Support.
I have tried again after your 5 instructions,without any difference.
Neo001
Legend
Theo1896
We all hope now to be fixed really really soon.
Is like 1 day now without a proper image.
Thank you all
LB666
Just applied update 1504 and it appears to have fixed the issue. No thanks to Samsung whose advice was just to wait
Arroway1
Thanks!
I too waited for a reply from Samsung, they said so, just wait - did not get it.
I will try the new opdate, and se if it works.
Arroway1
It did solv the problem!!
AlexVo
I do have absolutely same issue, but with QE75QN95B, I bought brand new TV and only watched youtube for 3 hours, then noticed that the brightness started to dim automatically on the light scenes, also refresh rate became low (or it is a very noticable flickering). After awhile the brightness became as lowest as possible. I tried all possible settings and recommendations from Samsung and community, factory reset, updated the firmware using usb to 1503 (was 1430 initially), but nothing helped. When I turn on TV it is bright enough, but after opening any video in any app like youtube, netflix etc - brightness is going down. The "flickering" (or very low refresh rate) is from the power on.
I cannot update to firmware 1504 as my motherboard is T-PTMDEUC, for which 1504 version is not yet available. Does anybody know, if I should wait for an update that will fix this issue or it is related to motherboard hardware problem?
For years I believed Samsung and have a lot of devices from it, but now, I am not sure if it is the same company anymore.
