Please help
(Topic created on: 27-04-2023 08:03 AM)
Chinenye33
Hello there. When playing TV shows from USB. I cant play with the subtitles. And when i go to settings The subtitle (CC) option is set on off and its greyed out. So i cant change it. How can i solve this? My Samsung is series 4/4002 LEDTV
2 REPLIES 2
nowdeleted
Big Cheese
Subtitles are normally a add on to the program. So unless you have a separate file on the usb stick, you can't play Subtitles.
Ry-Galaxy
Navigator
The subtiles would need to be hard encoded to work playing from USB on your TV, if they're a seperate file the TV won't be able to read them
