Plastic Casing Splitting on TV
(Topic created on: 29-04-2020 02:36 PM)
iCamH
Hi there,
I've owned my Samsung TV for a few years now and have recently noticed the plastic casing is splitting apart in the bottom right corner and seems to be getting gradually wider.
Is there a fix you can recommend I do for this or do you think it will be okay just leaving it?
Any help would be greatly appreciated!
Thanks,
4 REPLIES 4
CarloL
Hotshot
Hey @iCamH! Does the TV work fine aside from this issue?
iCamH
Hi, yes it does. :smiling-face:
Just a bit worried about it in case it gets any wider overtime and if there's anything I could possibly try to fix.
Also the model number is SAMSUNG UE40J5200, is this common for this TV?
CarloL
Hotshot
Okay, that's good. I would be keeping an eye out on it for now and should it get any worse, I would get in touch with the Samsung TV specialists via Live Chat to see if an engineer can look at it once the Support Centres open again. The TV and AV specialists can be reached here: https://www.samsung.com/uk/support/livechat/
iCamH
Awesome, thanks for your help :smiling-face:
