Pin code digits not showing
(Topic created on: 06-01-2024 07:45 PM)
Mladen5
I have an UE43AU8000KXXU, when i need to enter my 4 digit pin, i see no digits appear on screen through which to use my smart remote to enter the digits. I can use my basic remote to then enter the digits via the remote keypad, but i tend to use my smart remote as the primary method of control. Anyone know how i get the on screen entry back?
3 REPLIES 3
Gurky
Helping Hand
Used to get this a lot when I was store based. Usally repairing the remote is step one and closing and reopening the menu step 2
Mladen5
The remote works fine, im thinking its software or a setting
Neo001
Legend
Try with the Smartthings app TV remote.
