10-07-2018 11:52 PM in
TVHi all , been reading through some posts and something that seems to be very common with Samsung TVs is picture judder , I have a ue49mu6500 TV and had the judder set to custom / 10 but it seemed better set to auto !! So my question is , do Samsung actually look at issues like judder and send out a firmware/software update to sort it ??? Also how do I know if my TV has the latest update ??? Thanks , Dave
11-07-2018 07:21 AM in
TVHad a major issue with my curved tv douing this, so i sent it back. Got the MU series 120hz instead and seems better, but the blur motion even when i custom it is still there. I would imagine samsung do know about this and as of yet nothing is done? the judder/blur effect is worse when for example you are watching rugby and the camera is showing the full pitch and the judder kicks in then.
11-07-2018 08:33 AM in
TVSeems like Samsung know about these issues but won't do anything about it , since I changed the judder setting from 10 to auto it seems to have improved it , must admit tho , if I'd have known about this I wouldn't have bought it
11-07-2018 08:45 AM in
TV12-07-2018 11:15 PM in
TVHi , update on the bit of picture judder I've got , I've turned off auto motion plus and put film mode to auto 1 and it's improved it loads , tht I'd let y'all know if someone else having this issue , cheers
16-07-2018 08:05 AM in
TVHi
The trouble in turning it off is you immediately get a resolution drop on anything that moves, it is a necessity with displays like LCDs, which is why all LCD TVs have something similar. If you don't notice this resolution drop then you are lucky or sat too far away from the TV (which probably means you don't need a 4K set).
Turning it off for us isn't an option as the constant blurring of anything that moves is worse than the judders.
Regards
Phil
16-07-2018 09:42 AM in
TVYeah you can notice the drop in the picture quality, so I don't put mine down. It's a case of Samsung issue which they don't address. I was in Curry's looking at tvs and when I have a Samsung and they show videos on display, you can clearly see the judder etc on them.
17-07-2018 11:37 AM in
TVHi @Edgie70, Firmware 1230 was released just over a month ago but was recently replaced by 1220 on the Samsung site https://www.samsung.com/uk/support/model/UE49MU6500UXXU/ Sometimes you may need to tweak the settings depending on content though picture quality is obviously paramount, though if current setting works for you fine. For UHD you certainly need to be fairly close to set for best effects. Generally experts recommend keeping Auto Motion plus at a minimum (largely due to soap opera effect) Some general guidance if of interest https://www.whathifi.com/advice/how-to-set-your-tv-and-get-best-picture
One Ui 5.0,Android 13 .
17-07-2018 06:48 PM in
TVHi , my software version is 1210.8 , I presume that this update can be done OTA ??
17-07-2018 06:49 PM in
TVHi , what setting do you have judder set to between 1 and 10 ?? Thanks
