Password Reset does not work NU / 7 Series Smart TV HELP PLEASE, support does not call back
(Topic created on: 04-07-2021 11:33 AM)
SimonB_in_UK
TV
My password is not 0000  but i have never changed which is odd.
anyway I have tried , tv on standby , then , mute > 8 > 2 > 4
does not work, tv turn on when i hit 2
I'm really sick of this TV, Samsung has installed a ton of APPs I do NOT  want, and as a result it has very little memory left.
2 REPLIES 2
LiquidSnake
Troubleshooter
TV
Try talking to the text chat and see if they can sort out your problem for you 😀. If not, try contacting one of the moderators and I'm sure they will be happy to help 😁.
AndrewL
TV
@SimonB_in_UK: Can you try heading to Settings > General > System Manager > Change PIN, and try entering '1234' or '1111'. If you'd like to reset the PIN, please press the following buttons in sequence, with your TV turned on.
Smart Remote: Select VOL button > Volume Up > Return (backward facing arrow) > Volume Down > Return > Volume Up > Return
Standard Remote: Mute > Volume Up > Return > Volume Down > Return > Volume Up > Return
