Optical cable lock release
(Topic created on: 09-02-2022 11:06 AM)
Members_nkXryXp
Hello
Anyone knows how to unplug the optical cable connection on the Samsung TV QLED qe55q60aauxxu 55?
I bought a converter which came with a cable that I need to remove for return but it seems the connection at the back of the TV is locked in. I can't work out how to remove this and don't want to use force at the risk of damaging the TV  connector.  I would keep it on but I feel the cable is a poor quality one that needs to go.
Annoying thing!
Any help will be greatly appreciated. Many thanks! in advance.
2 REPLIES 2
xSteveuk
Mastermind
Hi,
How to Remove an Audio Optical Cable
Turn around the first device from which you want to disconnect the optical cable. ...
Locate the optical cable you want to remove. ...
Grip the head of the plug and gently pull it away from the port until it comes out.
Use a pair of pliers if needed and pull straight out slowly
antikythera
Black Belt
Also there's no difference with optical cables, they either work or don't at all. Don't be sucked in by the lure of gold plated braded cables that promise superior signals because an Amazon basics cable is perfectly fine. The same applies to HDMI cables
