21-02-2021 06:07 PM in
TVMy Q75QE95t was wall mounted on Monday and therefore been in use for 6 days. Today, the one connect box is failing to recognise the equipment connected to it I.e sky q box, 4k blu ray player, blu ray disc recorder and dvd recorder. I phoned Samsung support who went through all the possible solutions, including taking remote control of my tv and performing a factory reset. Nothing worked. The lady suggested that I contact the retailer and demand a new TV asap. The lady thought the fault lay with the TV itself and not the one connect box. I am livid as this is a £3000 TV and I expected years of service from it, not days. This is already a replacement TV for a 65 inch KS8000 that also failed with a back light issue. Anybody have any ideas what could be causing this?
23-02-2021 06:15 PM in
TVHi @Matthew
Could you confirm if the TV displays anything or if you just have a black screen?
26-02-2021 11:31 PM in
TVHi, it plays Freeview OK as well as the apps built into the TV and it also plays content from a USB stick, attached to the one connect box. It just won't play anything through the hdmi sockets. They appear as unknown on the screen.
27-02-2021 03:38 PM in
TVIt sounds as though your TV needs a reset of the HDMI ports. If you contact our Support team on 0333 000 0333, they'll be able to run through this with you, or make a remote connection to the TV to do this for you.
Hope this helps!
