ONE CONNECT BOX COMPATIBILITY
(Topic created on: 24-03-2021 11:19 PM)
nikosvl97
Hello guys,
i bought a used Samsung TV  UE55JS9090Q and i realised that the ONE CONNECT BOX was not included...
Do you know which one i have to buy ? i searched in internet and i found hundred of them.. Is any difference between the models ? Any ideas which one do i have to buy ?
Thanks for your help!
2 REPLIES 2
strawberry cake
Hotshot
@nikosvl97
please contact Customer Support to enquire if they can send you one free
if not, get the exact part code (model code) from them, for your easy search online
 (\_/)
(")_(") strawberry cake so delicious
nikosvl97
Vielen Dank für deine Antwort.
Leider können sie nicht viel helfen.. Die haben mir ein Telefonnummer von partner gegeben usw.  Model code wissen die auch nicht..
Ich werde gleich da anrufen
