Go to solution Solved
One connect 15m cable
(Topic created on: 06-03-2021 12:33 AM)
Tonys44
I know this has been asked before but I just purchased the Samsung the frame 55 inch 2020 tv. The 5m cable it comes with is not long enough as the tv is going above a fireplace so the one connect box will need to be about 7m away, as there are sliding doors either side of the fireplace.  Cannot find a compatible long invisible cable anywhere other than the VG-SOCR15/ZA which is out of stock everywhere apart from USA and CANADA
Shazzkid
Troubleshooter
Its advertised as compatible on Samsung US website, and reviews and answered questions on the US Amazon page confirms that it is compatibile.
https://www.amazon.com/ask/questions/asin/B07S18XXL5/ref=ask_mdp_dpmw_ql_hza?isAnswered=true
3 REPLIES 3
Shazzkid
Troubleshooter
I believe that specific cable was discontinued in the UK
Tonys44
I can get it shipped from US but do you know if it is compatible with the 2020 Samsung frame?
Shazzkid
Troubleshooter
